Отговори на тема  [ 20 мнения ]  Отиди на страница Предишна  1, 2
Проблем с DS18B20
Мнение Re: Проблем с DS18B20
Аз скоро имах подобен проблем. Оказа се, че не захранвам правилно датчика. Като размених Vcc и GRD(противно на дейташийта) всичко тръгна. И използвам една готова библиотека вместо да си играя да пиша програма.
Поздрави!
www.elkran.com
Пет Сеп 07, 2012 5:51 pm
Регистриран на: Пет Сеп 07, 2012 11:17 pm
Ow_Reset(&PORTE,2); // Onewire reset signal
Ow_Write(&PORTE,2,0xCC); // Issue command SKIP_ROM
Ow_Write(&PORTE,2,0x44); // Issue command CONVERT_T
Delay_us(120);
Ow_Reset(&PORTE,2);
Ow_Write(&PORTE,2,0xBE); // Issue command READ_SCRATCHPAD
Delay_ms(400);
unsigned short Ow_Read(unsigned short *port, unsigned short pin);
unsigned short Ow_Reset(unsigned short *port, unsigned short pin);
void Ow_Write(unsigned short *port, unsigned short pin, unsigned short par);
#define Broi_Datchici 4
#define D_PIN_PORT PORTA
#define D_PIN_NUM 0
#define D_TRIS_PORT TRISA
void D_ReadRom(char *address)
char count;
Ow_Write(& D_PIN_PORT, D_PIN_NUM, 0x33); //-- Read Rom
//-- Read in the ROM code from the Device
for(count=0;count<8;count++)
address[count]=Ow_Read(& D_PIN_PORT, D_PIN_NUM);
// *address=D_Read();
// address++;
void D_MatchRom(char *address)
char count;
Ow_Write(& D_PIN_PORT, D_PIN_NUM,0x55); //-- Match Rom
//-- Send the Address ROM Code.
Ow_Write(& D_PIN_PORT, D_PIN_NUM, address[count]);
void ReadTemperature(void)
char count;
Ow_Reset(& D_PIN_PORT, D_PIN_NUM); // Onewire reset signal
Ow_Write(& D_PIN_PORT, D_PIN_NUM,0xCC); // Issue command SKIP_ROM
Ow_Write(& D_PIN_PORT, D_PIN_NUM,0x44); // Issue command CONVERT_T
Delay_us(120);
//-- Read First Device
Ow_Reset(& D_PIN_PORT, D_PIN_NUM); // Reset the Bus Again
#if (Broi_Datchici ==1)
Ow_Write(& D_PIN_PORT, D_PIN_NUM,0xCC);// Skip ROM
#else
D_MatchRom(ADDR1);
#endif
Ow_Write(& D_PIN_PORT, D_PIN_NUM,0xBE); // Read Scratch Pad Command
// Delay_ms(400);
for(count=0;count<9;count++)
DATA1[count]=Ow_Read(& D_PIN_PORT, D_PIN_NUM);
Съб Сеп 08, 2012 3:24 pm
Момци, имам малък проблем. Залях един такъв индикатор с епоксидна смола(с цел да стане водоустойчив), но сега не показва вярно. Датчикът е свързан към контролера с кабели 1.5м. Резултата, който ми връща контролера е 208-212 градуса за стайна температура. Като го хвана с ръка се качва до 230++ и после като го пусна спада пак до първоначалните стойности. Някой имал ли е подобен проблем???
www.elkran.com
Сря Сеп 12, 2012 2:34 pm
Май има писано по темата във форума. Някой се беше сблъскал челно с тоя влак...
Сря Сеп 12, 2012 3:24 pm
stoyanoff написа:
Можеш ли, да постнеш целият scratch pad тук? Тези градуси, които четеш са извън обхвата на този сензор, ако не бъркам ...
Чет Сеп 13, 2012 2:23 pm
