Код: #ifdef AT42_SOFT #define AT42_SDA PIN_C1 #define AT42_SCL PIN_C0 #use i2c(master, sda=AT42_SDA, scl=AT42_SCL,STREAM=AT42) #else #use i2c(master, force_hw ,fast=450000, STREAM=AT42, I2C1) #endif
#define ADDR 0x1b #define ADDR_W 0x36 #define ADDR_R 0x37
void at42_init() { #ifdef AT42_SOFT output_float(AT42_SDA); output_float(AT42_SCL); #else // i2c_init(AT42,1); #endif } |
