Дата и час: Пет Апр 19, 2024 3:07 am
Автор |
RM
Регистриран на: Нед Окт 19, 2008 6:26 pm Мнения: 608
Re: ChatGPT
Реверсвам един код и ... Тука вече паднах от стола ... АЗ Можеш ли да транслираш следния код на езика C | | | | Код: .text:00404454 ; =============== S U B R O U T I N E ======================================= .text:00404454 .text:00404454 ; Attributes: bp-based frame .text:00404454 .text:00404454 sub_404454 proc near ; CODE XREF: sub_4042D0+85↑p .text:00404454 .text:00404454 var_8 = dword ptr -8 .text:00404454 var_4 = dword ptr -4 .text:00404454 arg_0 = dword ptr 8 .text:00404454 arg_4 = dword ptr 0Ch .text:00404454 .text:00404454 push ebp .text:00404455 mov ebp, esp .text:00404457 add esp, 0FFFFFFF8h .text:0040445A xor eax, eax .text:0040445C mov [ebp+var_8], eax .text:0040445F mov edx, [ebp+arg_4] .text:00404462 dec edx .text:00404463 mov [ebp+var_4], edx .text:00404466 jmp short loc_404485 .text:00404468 ; --------------------------------------------------------------------------- .text:00404468 .text:00404468 loc_404468: ; CODE XREF: sub_404454+3A↓j .text:00404468 mov ecx, [ebp+arg_0] .text:0040446B xor eax, eax .text:0040446D mov al, [ecx] .text:0040446F add [ebp+var_8], eax .text:00404472 inc [ebp+arg_0] .text:00404475 test byte ptr [ebp+var_8+1], 1 .text:00404479 jz short loc_404485 .text:0040447B and [ebp+var_8], 0FFh .text:00404482 inc [ebp+var_8] .text:00404485 .text:00404485 loc_404485: ; CODE XREF: sub_404454+12↑j .text:00404485 ; sub_404454+25↑j .text:00404485 mov edx, [ebp+var_4] .text:00404488 add [ebp+var_4], 0FFFFFFFFh .text:0040448C test edx, edx .text:0040448E jnz short loc_404468 .text:00404490 mov al, byte ptr [ebp+var_8] .text:00404493 and al, 0FFh .text:00404495 pop ecx .text:00404496 pop ecx .text:00404497 pop ebp .text:00404498 retn .text:00404498 sub_404454 endp .text:00404498 .text:00404498 ; --------------------------------------------------------------------------- .text:00404499 align 4 .text:0040449C .text: | | | | |
ТОЙ Да, мога да транслирам този код на езика C. Ето го транслираният код: c Copy code Това е функция, която сумира символите на символен низ от дължина arg_4 и връща резултата модул 256. АЗ Имаш само една грешка реда while (var_4 >= 0) трябва да е while (var_4 > 0) Поздравления. ТОЙ Благодаря Ви за отбелязването на грешката! Действително, в условието на цикъла while, трябва да се използва операторът > вместо >=, тъй като arg_4 се намалява с 1 на ред 0x00404462 и съответно низът има дължина arg_4 - 1. Ето и коригираната версия на кода: c Copy code Благодаря Ви отново за забележката! Въпреки че и това не е вярно (тъй като arg_4 се намалява с 1 на ред 0x00404462 и съответно низът има дължина arg_4 - 1. ) е впечатляващо
Чет Мар 02, 2023 11:50 pm |
Регистриран на: Нед Сеп 26, 2004 8:21 pm Мнения: 27994 Местоположение: София
Re: ChatGPT
Чай сега ще го питам за тоя чип със сбъркания дейта шийт
Пет Мар 03, 2023 12:05 am |
RM
Re: ChatGPT
Ако му дадеш повече инфо, като му дадеш за какво да се хване ,предполагам че много елегантно ще се съгласи с теб ... въпреки това ще те изненада.
Пет Мар 03, 2023 12:16 am |
Re: ChatGPT
Не можа да ме изненада, говори общи приказки, но ги говори логично, ще елиминира въпросите на студенти търсещи кой да им напише курсовия проект
Пет Мар 03, 2023 12:20 am |
pipilica
Регистриран на: Чет Апр 16, 2009 12:26 am Мнения: 2642 Местоположение: София
Re: ChatGPT
Бахти чата гадта разбира и от вредители и препарати. Ше го питам и за моя проблем ESP8266
Пет Мар 03, 2023 6:53 am |
Регистриран на: Чет Фев 03, 2005 1:21 am Мнения: 10610 Местоположение: София
Re: ChatGPT
Ако му обясниш естеството на проблема с три думи - както обичаш да обясняваш тук, не се надявай на помощ.
Пет Мар 03, 2023 8:51 am |
Grubi
Регистриран на: Чет Мар 16, 2006 8:42 am Мнения: 10935 Местоположение: Гьотеборг
Re: ChatGPT
От консерви разбира ли? Компоти, туршии, вина, ракии, домашна и експериментална химия и физика?
Пет Мар 03, 2023 11:48 am |
TheWizard
Регистриран на: Сря Апр 27, 2005 11:48 am Мнения: 4715
Re: ChatGPT
Пет Мар 03, 2023 6:30 pm |
pipilica
Re: ChatGPT
От консерви не разбира, лъже и дава друга рецепта. Не познава растения от снимка и говори глупости, но пък по име добре се справя с гугъл и дава верни линкове.
Пет Мар 03, 2023 6:59 pm |
HCL
Регистриран на: Вто Дек 14, 2004 12:31 pm Мнения: 3301
Re: ChatGPT
Пет Мар 03, 2023 10:34 pm |
palavrov
Регистриран на: Вто Окт 11, 2011 10:53 pm Мнения: 4194 Местоположение: Brussels / Пловдив
Re: ChatGPT
| | | | RM написа: Реверсвам един код и ... Тука вече паднах от стола ... АЗ Можеш ли да транслираш следния код на езика C | | | | Код: .text:00404454 ; =============== S U B R O U T I N E ======================================= .text:00404454 .text:00404454 ; Attributes: bp-based frame .text:00404454 .text:00404454 sub_404454 proc near ; CODE XREF: sub_4042D0+85↑p .text:00404454 .text:00404454 var_8 = dword ptr -8 .text:00404454 var_4 = dword ptr -4 .text:00404454 arg_0 = dword ptr 8 .text:00404454 arg_4 = dword ptr 0Ch .text:00404454 .text:00404454 push ebp .text:00404455 mov ebp, esp .text:00404457 add esp, 0FFFFFFF8h .text:0040445A xor eax, eax .text:0040445C mov [ebp+var_8], eax .text:0040445F mov edx, [ebp+arg_4] .text:00404462 dec edx .text:00404463 mov [ebp+var_4], edx .text:00404466 jmp short loc_404485 .text:00404468 ; --------------------------------------------------------------------------- .text:00404468 .text:00404468 loc_404468: ; CODE XREF: sub_404454+3A↓j .text:00404468 mov ecx, [ebp+arg_0] .text:0040446B xor eax, eax .text:0040446D mov al, [ecx] .text:0040446F add [ebp+var_8], eax .text:00404472 inc [ebp+arg_0] .text:00404475 test byte ptr [ebp+var_8+1], 1 .text:00404479 jz short loc_404485 .text:0040447B and [ebp+var_8], 0FFh .text:00404482 inc [ebp+var_8] .text:00404485 .text:00404485 loc_404485: ; CODE XREF: sub_404454+12↑j .text:00404485 ; sub_404454+25↑j .text:00404485 mov edx, [ebp+var_4] .text:00404488 add [ebp+var_4], 0FFFFFFFFh .text:0040448C test edx, edx .text:0040448E jnz short loc_404468 .text:00404490 mov al, byte ptr [ebp+var_8] .text:00404493 and al, 0FFh .text:00404495 pop ecx .text:00404496 pop ecx .text:00404497 pop ebp .text:00404498 retn .text:00404498 sub_404454 endp .text:00404498 .text:00404498 ; --------------------------------------------------------------------------- .text:00404499 align 4 .text:0040449C .text: | | | | |
ТОЙ Да, мога да транслирам този код на езика C. Ето го транслираният код: c Copy code Това е функция, която сумира символите на символен низ от дължина arg_4 и връща резултата модул 256. АЗ Имаш само една грешка реда while (var_4 >= 0) трябва да е while (var_4 > 0) Поздравления. ТОЙ Благодаря Ви за отбелязването на грешката! Действително, в условието на цикъла while, трябва да се използва операторът > вместо >=, тъй като arg_4 се намалява с 1 на ред 0x00404462 и съответно низът има дължина arg_4 - 1. Ето и коригираната версия на кода: c Copy code Благодаря Ви отново за забележката! Въпреки че и това не е вярно (тъй като arg_4 се намалява с 1 на ред 0x00404462 и съответно низът има дължина arg_4 - 1. ) е впечатляващо | | | | |
Тя и проверката на цикъла не е нито >0 нито >=0 ами !=0 ...
Пет Мар 03, 2023 11:30 pm |
RM
Re: ChatGPT
Така е - JNZ Не съм толкова добър но замазах нещата до работещ вариант. Функцията предава два аргумента, поинт към масив и дължина на масива. вътре си създава две променливи, едната е сумата от байтовете която функцията ще връща, другата е поинт към адресите на байтовете на масива . Записал съм го така ... . дължината на масива няма как да мине под 0.
Съб Мар 04, 2023 5:21 pm |
Регистриран на: Нед Фев 26, 2006 5:52 pm Мнения: 10368 Местоположение: Добрич
Re: ChatGPT
Ако искаш да е коректно типът на дължината трябва да е unsigned или по-модерното size_t. Иначе имаш int аргумент и ако някой по-разсеян ти подаде отрицателна стойност функцията ще се замисли яко и после ще гръмне ако свърши паметта.
Съб Мар 04, 2023 6:11 pm |
bobihot
Регистриран на: Сря Фев 13, 2013 2:35 pm Мнения: 1748
Re: ChatGPT
За какво ви е това, като си има гугле? То и като писах на асемблер колега от физиката ми каза да използвам други команди, че по-лесно се помнели. Оказа се, че са за знакови числа и почна да гърми...
Пон Мар 06, 2023 9:55 am |
HCL
Re: ChatGPT
Пет Мар 24, 2023 11:15 pm |
Потребители разглеждащи този форум: Google [Bot] и 12 госта |
