Дата и час: Пет Ное 13, 2026 11:08 pm
къде е термистора на платката,или е в проца
Регистриран на: Нед Ное 21, 2004 11:31 pm Мнения: 10166
 Re: къде е термистора на платката,или е в проца
СПРИ СЕ БЕ, ЧОВЕК!
| Пон Фев 27, 2017 11:22 am |
ike
| Пон Фев 27, 2017 12:28 pm |
Регистриран на: Нед Сеп 26, 2004 9:21 pm Мнения: 31057 Местоположение: София
..пошел в разнос ... за подлите русофили като мен, вече дали трябва да е пошел или ушел ...
| Пон Фев 27, 2017 3:09 pm |
am stereo
Регистриран на: Съб Дек 08, 2007 10:51 am Мнения: 1869 Местоположение: ♪♫♣♠|☼◙▲♦▼☻╬☺∞
_________________ DT-838 ((( STEREO ПОЗДРАВ))) за форума - https://youtu.be/xy921Pn3lhA
| Вто Фев 28, 2017 12:59 am |
am stereo
ТОВА Е по-яко
had to import my videos from my HDR-GW55VE with the Play Memories Home Software, I simply copied the CLIPINF and STREAM folders (including all the .CPI and .MTS files contained within these folders) from the SD card to my HDD. However, as I only discovered now, I did a mistake by not copying the PLAYLIST folder, and the INDEX.BDM and MOVIEOBJ.BDM files.
When I learnt that I had to import the videos via PMH in order to have all the management information included, I recreated the AVCHD folder structure according to what I read in the forums and did the following: - put files on an SD card - insert SD card in camera - let camera repair the file structure (by placing the file I had copied to a newly created AVCHD_BK folder) - insert SD card in computer - start import from SD card with PMH.
PMH recognised my SD card and imported the videos but I got the message “Import videos without management information”.
Once videos were imported via PMH, I noticed that: - file extensions are changed from .MTS to .M2TS (which is normal) - files have not been renamed with date/time information, e.g. files are named XXXXX.M2TS instead of YYYYMMDDHHMM.M2TS - PMH does not see any GPS data (I find this strange since the GPS data is included in the Exif information of the .MTS files)
I know that I can manually set the GPS data in [map view], but since I have some 200 files, this would be quite cumbersome.
Is there any way to recreate the missing .BDM and .MPL files so that files are imported with the proper GPS data? What else could I do in order to have PMH recognise the GPS data?
For illustration, I copy below the Exif information of a sample file.
Any help would be much appreciated.
Cheers, Teekai
ExifTool Version Number : 9.78 File Name : 00031.MTS Directory : I:/PRIVATE/AVCHD_BK/BDMV/STREAM File Size : 39 MB File Modification Date/Time : 2014:07:14 09:27:58+01:00 File Access Date/Time : 2014:12:28 00:00:00+01:00 File Creation Date/Time : 2014:12:27 19:40:42+01:00 File Permissions : rw-rw-rw- File Type : M2TS MIME Type : video/m2ts Video Stream Type : H.264 Video Audio Stream Type : A52/AC-3 Audio Audio Bitrate : 256 kbps Surround Mode : Not indicated Audio Channels : 2 Image Width : 1440 Image Height : 1080 Date/Time Original : 2014:07:14 10:27:28+01:00 Aperture Setting : Auto Gain : 0 dB Exposure Program : Program AE White Balance : Auto Focus : Auto (3.15) Image Stabilization : On (0x3f) Exposure Time : 1/1004 F Number : 3.4 GPS Version ID : 2.2.0.0 GPS Latitude Ref : North GPS Longitude Ref : East GPS Altitude Ref : Above Sea Level GPS Time Stamp : 09:27:30 GPS Status : Measurement Active GPS Measure Mode : 3-Dimensional Measurement GPS Dilution Of Precision : 1.46 GPS Speed Ref : km/h GPS Speed : 0.468 GPS Track Ref : True North GPS Track : 55.9 GPS Map Datum : WGS-84 Make : Sony Camera Model Name : HDR-GW55VE Audio Sample Rate : 48000 Duration : 0:00:30 Aperture : 3.4 GPS Altitude : 1918.9 m Above Sea Level GPS Latitude : 47 deg 2' 22.78" N GPS Longitude : 10 deg 34' 1.18" E GPS Position : 47 deg 2' 22.78" N, 10 deg 34' 1.18" E Image Size : 1440x1080 Shutter Speed : 1/1004
| Вто Фев 28, 2017 10:33 am |
Регистриран на: Чет Фев 03, 2005 2:21 am Мнения: 13017 Местоположение: София
Решил си да препишеш целия интернет? Доста амбициозно начинание...
| Вто Фев 28, 2017 1:44 pm |
palavrov
Регистриран на: Вто Окт 11, 2011 11:53 pm Мнения: 4604 Местоположение: Brussels / Пловдив
Преди 20-на години един приятел почти беше успял да го свали целия интернет на CD-та
| Вто Фев 28, 2017 2:26 pm |
am stereo
| Сря Мар 01, 2017 6:25 am |
