Hi Tech C и *.Н файл
Мнение Hi Tech C и *.Н файл
Продължавайки упорито да тормозя компилатора(и себе си) стирнах до следната ситуация:
#define XTAL_FREQ 36MHZ
#include <pic18.h>
#include <math.h>
#include <stdlib.h>
#include <pic18f4550.h>
__CONFIG(1,HS & FCMDIS & IESODIS);
__CONFIG(2,VREGDIS & PWRTDIS & BORDIS & WDTDIS & WDTPS32K);
__CONFIG(3,CCP2RC1 & PBADDIS & LPT1DIS & MCLREN);
__CONFIG(4,STVREN & LVPDIS & XINSTDIS & DEBUGDIS & ICPORTDIS);
__CONFIG(5,UNPROTECT);
__CONFIG(6,UNPROTECT);
__CONFIG(7,UNPROTECT);
void main()
Init();
while(1) //Loop Forever
void Init(void)
PORTA = 0;
TRISA = 0b00101101; // Set RA4 and RA2 as outputs
PORTC = 0;
TRISC = 0b00000011; // Set RC0 and RC1 as inputs, rest outputs
CMCON = 0b00000111; // Disable the comparator
IRCF0 = 1; // Used to set intrc speed to 8 MHz
IRCF1 = 1; // Used to set intrc speed to 8 MHz
IRCF2 = 1; // Used to set intrc speed to 8 MHz
CCP1CON = 0b01001100; // Full bridge PWM forward
ECCPAS = 0;
PR2 = 0x3F; // Sets PWM Period at 31.2 kHz
T2CON = 0; // TMR2 Off with no prescale
CCPR1L = 0; // Sets Duty Cycle to zero
TMR2ON = 1; // Start Timer2
ANSEL = 0b00110101; // Configure AN0,AN2,AN4 and AN5 as analog
VCFG = 0; // Use Vdd as Ref
ADFM = 1; // Right justified A/D result
ADCS0 = 1; // 16 TOSC prescale
ADCS1 = 0;
ADCS2 = 1;
CHS0 = 0; // Channel select AN0
CHS1 = 0;
CHS2 = 0;
ADON = 1; //Turn A/D on
ei(); // enable IRQ
void interrupt Isr()
// IRQ program
Когато го компилирам ми дава следните грешки:
Error[111] C:\Program Files\HI-TECH Software\PICC-18\9.50\include\pic18f4550.h 977 : redefining preprocessor macro "STVREN"
Error[111] C:\Program Files\HI-TECH Software\PICC-18\9.50\include\pic18f4550.h 978 : redefining preprocessor macro "STVRDIS"
Error[111] C:\Program Files\HI-TECH Software\PICC-18\9.50\include\pic18f4550.h 980 : redefining preprocessor macro "LVPEN"
Error[111] C:\Program Files\HI-TECH Software\PICC-18\9.50\include\pic18f4550.h 981 : redefining preprocessor macro "LVPDIS"
Error[111] C:\Program Files\HI-TECH Software\PICC-18\9.50\include\pic18f4550.h 983 : redefining preprocessor macro "ICPORTEN"
Error[111] C:\Program Files\HI-TECH Software\PICC-18\9.50\include\pic18f4550.h 984 : redefining preprocessor macro "ICPORTDIS"
Error[111] C:\Program Files\HI-TECH Software\PICC-18\9.50\include\pic18f4550.h 986 : redefining preprocessor macro "DEBUGDIS"
Error[111] C:\Program Files\HI-TECH Software\PICC-18\9.50\include\pic18f4550.h 987 : redefining preprocessor macro "DEBUGEN"
От къде по дяволите се предефинира? И как се ползват файловете <pic_xxx_.h> в Hi-Tech компилатора?Ако искам да използвам дадено име на бит примерно TMR0ON,всеки път ли трябва да се дефинира
static bit TMR0ON @ ((unsigned)&T0CON*8+0); и става едно писане.....Та как се ползва <pic18f4550.h> щото в него са дефинирани дези неща?
Чет Апр 26, 2007 4:41 pm
#include <pic18.h>
#include <math.h>
#include <stdlib.h>
Не ти трябват чукорнайсе файла с дефиниции. Махни първия :)
Чет Апр 26, 2007 4:59 pm
Регистриран на: Сря Яну 25, 2006 12:47 pm
Местоположение: Varna
Аз ползавам Hi-Tech само за 16-те.
Мисля, че Димитър е прав.
Разгледай общия файл pic18.h и виж там как е
дефиниран твоя процесор.
Аз правя така:
#ifndef _16F876A
#define _16F876A // This will include a header file for 16F876A
#endif
#include <pic.h>
и няма проблеми
Пет Апр 27, 2007 9:21 am
Нещо не са го излекували както трябва компилатора.Ползвам 9.61PRO за 18 серия.И да го дефинирам както каза bkulev, пак дава "redefining preprocessor macro "За момента ме спасява :
#ifndef _18F4550
#define _18F4550 // This will include a header file for 18F4550
#endif
Обикновенно се компилира от втория път.Явно ще трябва да сменя лекарството.
Пет Апр 27, 2007 4:15 pm
Като намериш свястно лекарство, предложи го тук заедно с версията на компилатора.
Много хора ще са ти благодарни, предполагам :)
Пет Апр 27, 2007 4:18 pm
