Дата и час: Сря Ное 25, 2026 3:56 am
HCL
Регистриран на: Вто Дек 14, 2004 1:31 pm Мнения: 3871
 Re: Въпрос от физиката
Явно ползват ChatGPT при съставянето на тестовете вече...  |  |  |  | Цитат: The correct answer to the question "Which process releases energy?" is "combustion" or "burning" (г) изпарение. Combustion is a chemical reaction that releases energy in the form of heat and light, when a fuel reacts with oxygen. This process is used in many applications such as power generation, transportation, and heating.
"boiling" (в) кипене is not the correct answer to the question "Which process releases energy?". Boiling is a physical process that occurs when a liquid is heated to its boiling point, and the vapor pressure of the liquid is equal to the atmospheric pressure. During boiling, heat is added to the liquid to overcome the intermolecular forces that hold the liquid together, which causes the liquid to change its state to a gas. However, this process does not release energy, it simply changes the state of matter of a substance, from liquid to gas. It does not involve chemical reactions that release energy.
Melting (б) топене is also not the correct answer for the question "Which process releases energy?". Melting is a physical process that occurs when a solid is heated to its melting point and the intermolecular forces that hold the solid together are overcome. This process also changes the state of matter of a substance, from solid to liquid, but it doesn't release energy. Melting involves adding heat to a solid to overcome the intermolecular forces that hold the solid together. The heat added is absorbed by the solid and causes the solid to change its state to a liquid. The process is endothermic and the energy is absorbed by the substance, not released.
Diffusion (а) дифузия is also not the correct answer for the question "Which process releases energy?". Diffusion is a physical process that refers to the movement of particles from an area of higher concentration to an area of lower concentration. It is driven by the random motion of particles and the tendency of particles to distribute themselves evenly. Diffusion doesn't involve any energy release or absorption, it only occurs because of the natural motion of the particles. Diffusion can be observed in liquids, gases, and solids, but it's not a process that releases energy |  |  |  |  |
| Пон Яну 16, 2023 5:55 pm |
velio
Ем да, реално при изпарението не се отделя самостоятелна енергия - носят я частиците. При горенето се отделя лъчиста енергия, ама го няма във въпросника...
| Пон Яну 16, 2023 6:05 pm |
milenjs
д) е бил забравения отговор - топене
| Пон Яну 16, 2023 6:07 pm |
Моята малката е втори клас - за втори път в живота си се опитвам да обясня на второкласник че съществува число 1/2 и операция 1 - 2.... за 3/4 и за 0 - ххх да не говорим... А учителката и се води математик - в смисъл че тя подготвя и води извънклсните форми по математика. Тва малкото като каза че не може и че няма - край. А с голямата беше още по зле, щото нейната учителка беше по английски. На малката поне не им казва директно че не може, на голямата направо им беше казала в прав текст че не може.
| Пон Яну 16, 2023 6:17 pm |
отговорите в тия класове, че и в по-горните са свързани директно с нещо което са учили, и за конкретният частен случай може би отговора е правилен. Вече не се учат принципи а частни случаи
| Пон Яну 16, 2023 6:20 pm |
Desert Leo
| Пон Яну 16, 2023 6:25 pm |
nik
Топенето поглъща енергия, единствено изпарението отделя, защото изпарение имаме и при стайна температура
| Пон Яну 16, 2023 7:15 pm |
HCL
Интересното е, че като го питаш директно явно знае превода
[HCL] Как ще преведеш изпарение на английски, а изгаряне? [ChatGPT] "Evaporation" е превода на "изпаряване" на английски. "Combustion" е превода на "изгаряне" на английски.
| Пон Яну 16, 2023 7:23 pm |
Desert Leo
Що тогава електрониката на МиГ-25 се полива със спирт?
| Пон Яну 16, 2023 7:25 pm |
emilvtc
От личен опит стигам до извода, че определено трябва да си образоваме децата вкъщи ВЪПРЕКИ училището. В мнооого редки случаи се намират и наистина читави даскали (в моя случай учителката по английски на децата ми 1-3 клас), но по-скоро те са изключения.
До някъде е разбираемо, защото децата в началното училище не се записват в паралелките след някакъв подбор и работата на учителя е да се опита да няма изоставащи в класа, а не да работи с напредналите. Та както директора на училището ни обЕсни - всички влизат в училище с различно начално ниво и излизат с еднакво изходно ... (Е, освен ако някой родител не се занимава и инвестора време и пари за допълнително извънкласно обучение де).
В моя случай решението е децата ми да прекарват/губят възможно най-малко време в училище, за да имат време след това както за игра, така и за да се образоват извънкласно под родителски надзор.
| Пон Яну 16, 2023 7:41 pm |
HCL
Колегите в Америка разправят, че при тях първите години в даскалото били само за игра и социализиране. После (кога, 3 5 7 клас?) децата дърпали както трябвало. Ще ми интересно да чуя мнението на нашенци, чиито деца са обучавани там как виждат нещата.
| Пон Яну 16, 2023 9:18 pm |
ikarlo
Регистриран на: Пон Авг 24, 2020 4:45 pm Мнения: 217 Местоположение: София, Люлин 3
Отговор "д) Нито едно от изброените" е верният отговор. Няма тепърва да "измисляме" физиката!
| Пон Яну 16, 2023 10:06 pm |
Ами така е...като цяло първите няколконгодинин ги прекарватв игра, четене (не много), писане(не много) и математина почти без хич... За после незнам още
| Пон Яну 16, 2023 10:54 pm |
Ами явно и тяхното ниво е такова или изобщо не се интересуват какво учат децата им. Зле е навсякъде, и в държавни и в частни, разликата е само че някои са доста по-зле от други. Природните науки са под всякаква критика, вкл.математика. история и география изобщо няма да споменавам, те не знаят Атланта щат ли е, град ли е, дали изобщо в част от САЩ ...в някои училища е малко по-зле  общо взето единственото което имат шанс да научат в английски, евентуално, защото и граматическите им умения са под всякаква критика, но има училища в които поне се учат да пишат , в смисъл не само правопис но и да изразяват мислите си доколкото ги имат писменно  В университета не е много по-различно. Ако Руската/бивша Българска образователни системи са по-скоро академични, то тукашната е точно обратното. На икономиката и трябват работници а не мислители, такива се прави генерират, но и от тая гледна точка нивото е ужасно ниско. Но и ние в БГ ги догонваме с бесен темп.
| Пон Яну 16, 2023 11:26 pm |
HCL
В Германия казват за училищата, че е същата работа. Даже един познат говореше да се връщат в България заради образованието на щерките. Явно е глобален проблем или глобално мрънкане. Взимал съм дистанционни курсове в MIT и Stanford, и едва насмогвах на нивото на съкурсниците. Не че моето е нещо особено, но определено ме впечатлиха. Но предполагам голяма част не бяха ходили в американски училища
| Пон Яну 16, 2023 11:39 pm |
Потребители разглеждащи този форум: 0 регистрирани и 38 госта |
